Having bought a Samsung 80 GB HDD (SV8004H-Series).
Elitegroup P5VP-A+ doesn't support HDD bigger than 32 GB also latest BIOS i'd found is flashed (V2.2f). Mentioned version on the board (2.2h) isn't available anymore.
Anyone patched this one or can tell how to do it?
Thanks in advance
George
BIOS ID : 04/02/1999 -VP3-586B-W877-P5VP-A+
BIOS Date : 04/02/1999
BIOS OEM Signon : P5VP-A+ Ver 2.2f 04/02/1999
EDIT: Sorry. While writing these i found v2.2h at zdnet.de. Will try this now.
80GB: Elitegroup P5VP-A+
Nothing's going right.
Also 2.2h isn't able to address the 80 GB HDD correctly.
So someone outthere able to help me please?
George
George
I can take a look - a URL is often helpful if you've already found the latest and would like it patched. zdnet.de ? Hmmm...
[edit] Paths to www.zdnet.de seem to be down...
[edit] But http://www.ecs.com.tw/download/p5vpap.htm is up.
The file listed under 2.2h there is actually 1.1h, but if you change the target url you can download 2.2h. That's now patched and will be available at the URL in my sig within a few minutes.
