/Max
120GB: 06/16/1998-i440BX-W977-2A69KM4AC-00
allthesame
Hi! I got a new 120 gb Seagate Barracuda, but then i found out I could only use 32 gb.
I have tried to find a new Bios for my motherboard, but couldn't find any.. I would really appriciate some help.
/Max
/Max
Look for an MS-6xxx marking on your motherboard, then try here:
http://www.msi-computer.de/support/main.php3
The main Taiwanese site is having some problems right now.
allthesame
I downloaded the Bios from the page you gave me (even though german isn't my strength) and I ran it (followed the instrucions in the readme). It went fine and when I started up my computer it said bios version 2.9 instead of the previous 1.2.
But my computer still won't let me use more than 32 gb. When I start up it does the memory check, and then it shows primary master, primary slave, and secondary master (the hdd i want to use). but then it shows the next page where it says,
secondary master: LBA, UDMA 2,
and there it just stops. I wonder if I have to change something in the bios setup?
allthesame
It's ok, I managed to solve it myself. I got another bios from the msi.com.tw page, it seems to be up and running now..
thanks for the help anyway, this page is great..
