Is there a solution to recognize my 80 GB Maxtor ?
In the http://http://wims.rainbow-software.org I found patch only for 64 GB.
Is there any possibilities to write 80 GB patch for this BIOS ?
Could You answer, Rainbow ?
Thanks a lot.
80GB: ATREND ATC-6130 440LX AGP
Post your BIOS and OEM ID strings (to check if you have v1.0 or v2.0 board).
There is it
BIOS Date: 07/22/99
BIOS ID: 07/22/1999-i440LX-W977TF-ATC-6130C-EB
BIOS Eval: ATC-6130 VER:1.0 11 GS
BIOS ROM Size : 128K
Chipset: Intel 440EX/LX rev 3
Thanks for care.
BIOS Date: 07/22/99
Thanks for care.
Patched BIOS sent.
