Hello,
my new Western Digital Harddrive WD800 (80GB) is not recognized by my Toshiba Equium 3200M.
After doing some research I found a new BIOS from Toshiba and updated mine from 1.08.03 to 2.05.07
(here is a link to the BIOS update -> http://support.toshiba-tro.de/tools/bio ... _20507.zip )
BIOS details now:
Award Modular Bios v4.51PG
02/29/2000-i440ZX-w83977-2A69KB3NC-00
This helped for my processor upgrade to PIII 750
But the update didn't help for the Harddrive
I also found out that the Board is a BCM IN440ZX
The latest BIOS on there page is rev.1.02 Date 1/18/1999
(link to BCM BIOS -> http://www.bcmcom.com/tech/IN440ZX/bios/in440zx-102.zip )
I don't know if I can download and install that BIOS and if it would help.
Any further help would be greatly appreciated
Best regards from HMUe / Germany
Michael
80GB: 02/29/2000-i440ZX-w83977-2A69KB3NC-00
Michael.Oppermann
in440zx-102.zip contains this BIOS:
02/12/1999-i440BX-W83977-2A69KB3JC-00
PENTIUM II/III AGP/PCI/ISA SYSTEM BIOS VER:1.02(#20861)
New-style code found at 3060
=> 32GB bug patched successfully
The one from Toshiba says :
BIOS ID string: 02/29/2000-i440ZX-W83977-2A69KB3NC-00
BIOS OEM string: PENTIUM II/III AGP/PCI/ISA SYSTEM BIOS VER:2.05.07(#20863)
Searching for size calculation routine...Found at 2374
Searching for free space...Found at 19485
Patching code at 2373
I would stick with this one; it is the i440ZX version and is later. Pick up a patched version which should support 128GB HDD from the link in my signature if you want to test it; please give us feedback.
Michael.Oppermann
Nick,
thank you for your very fast reply.
You suggested to stay with the Toshiba BIOS and stated that you have a patched version for support 128 GB HDD. I followed your link but I'm unsure which BIOS I should download to test. Is it the (BCM IN440ZX).zip ?
Michael
Michael
Michael.Oppermann
Hi again,
I have downloaded the patched BIOS, flashed it and found no errors so far.
It works well with the new WD800 HDD and also with old HDD and operating system.
Thanks a lot Nick !!!!
(I only had some difficulties to download the patched BIOS.
The only way to get it was to use a download manager, and even that
took a long time (had to resume view times).
Just wanted to let you know.)
