I have a motherboard which, at this moment, is of a unkown manufacturer. The board is inside a Toshiba 3300M minitower.
The bios ID is 62-0107-000000-00101111-071595-V694V686.
I like to add a 120 GB disk but i'm afraid it won't work.
Reason is that when i play in my bios setup by disk setup "user" It *seems* so far that i won't can go beyond 66 GB or so.
AMI bios, PIII-1GHz, VIA 82C605, 3xPCI, 1xAGP, sound, USB.
Manufacturer seems to be D-ying (back-side of mobo says so); but the manufacterer code in de bios id is 000000.
1. will the 120 GB IDE drive work?
2. Can I use 66 GB and the leave rest not in use?
3. Anybody know where to get bios informatie (which drives it will support)
4. URL of place where I can download BIOS update?
Thanx,
Otto.
120GB: 62-0107-000000-00101111-071595-V694V686
What HDD do you have currently there?
