I have seen posts with the same topic but they all end up linking to http://wims.rainbow-software.org and there the id strings don't quite match exactly.
So, can someone please post a link to a bios for this MB supporting this HD or email it to me.
Current BIOS version is 1.0 10 GS
Tim
40GB: 01/08/98-i440LX-W977-ATC-6130C-00
The strings do not match exactly because Atrend changed the two last characters in the latest BIOS. It should work fine on your board.
I tried the Atrend ATC-6130 v1.0 BIOS at http://http://wims.rainbow-software.org with an Award flashing utility (awd802.exe) but the following error occured and the upgrade didn't go ahead: "The program file's part number does not match with your system."
Is this because the ID string isn't the same?
What can i do now?
What can i do now?
The file name of Award BIOS binary files is usually derived from the BIOS serial number. Because one file name resemble another, a customer may inadvertently use the wrong binary file when updating the system BIOS with the Award flash utility.
To help avoiding this problem, Award have added a new feature to AWDFLASH.EXE, version 5.33 and above - a warning message that appears if the program detects a mismatch between the BIOS binary file and the system board.
If a mismatch is detected, the following message appears when the user responds YES to the program prompt to flash the BIOS:
This warning message appears only if the binary file name you specified in the program differs from the existing file in your system.
If you receive this message, check carefully to ensure that you have the correct binary file for your system.
You can bypass checking the serial number by typing the following at the DOS command line:
Awdflash 2Axxxxxx.BIN /Py
The /Py switch immediately flashes the new binary file to the BIOS EPROM.
Ok,
The thing is, im not sure that i have the right BIOS.
Can anyone guarantee that the Atrend ATC-6130 v1.0 BIOS with ID string: 07/22/1999-i440LX-W977TF-ATC-6130C-EB
posted at http://wims.rainbow-software.org will work with a MB with the string:
If so ill try /Py
If so ill try /Py
There's no warranty here - you're doing everything at your own risk.
As your BIOS is "1.0 10 GS", that BIOS should work. It's one version newer ("ATC-6130 VER:1.0 11 GS") and patched.
Well i risked it....
and it worked fine.
The /Py didn't work so i ended up using Uniflash, which also gave me an error that the boot block didn't match, but i went ahead anyway.
So now i can happily use my 40Gb HD to its full extent.
Thanks for all your help.
and it worked fine.
Well it seems it wasn't fine after all.
The BIOS upgrade went fine, but now, for some reason, with the new BIOS, the HD is sometimes still read as 33GB.
I can change this with Maxtors program MadBlast, but it still goes back.
I think it happens when i access the BIOS or unplug the computer, or it could just be completely random.
Can anyone help??
Can anyone help??
i need to run 40GB hd on A-Trend mainboard
and i have problem with flashing[or finding] bios for:
info from: CTBIOS
BIOS date: 01/08/98
Awar Bios found: Award Modular BIOS v4.51PG
Award ID-String - 01/08/98-i440LX-W977-ATC-6130C-00
Board/BIOS-Version: ATC-6130 BIOS VER:1.0 03 - NOT FOR SALE *
(*) - LOL
when im trying to flash with Award bios flash utility 8.22a
with these bioses:
1. Atrend ATC-6130E
09/29/98-i440EX-W977-ATC-6130C-00
ATC-6130E VER:1.0 04 GS
i get: 'Unknown Flash Type!'
2. Atrend ATC-6130 v1.0
i get: 'The program file's part number does not match with your system', [ even with /Py option ]
dont know what to do, help!
[edit: i switched the BIOS ID and OEM ID (in Italic), couse i wrongly copied them into post. now is good]
info from: CTBIOS
BIOS date: 01/08/98
(*) - LOL
with these bioses:
1. Atrend ATC-6130E
Please use our patched ATC-6130 V1.0 Bios from here :
http://wims.rainbow-software.org/
Use Uniflash to update your Bios - do not use awdflash !
