I have a
60 GB Fujitsu MHS2060AT Harddrive in my PII 400 MHz Notebook. And it is not recognized.
My Bios Data:
Award Modular BIOS v4.51PGM (1984-1999)
V1.17 02/11/2000
Award Plug and Play BIOS Extension v1.0A
02/11/2000-BANISTER-2A69NC2AC-00
I could not find a newer upgrade for my BIOS. Can I resolve my Problem when I order a BIOS upgrade kit at www.unicore.com??
And will this upgrade kit surely work?
I appreciate your help.
Greetings, Harry
60 GB: 02/11/2000-BANISTER-2A69NC2AC-00 Award v.451 PGM
Google search says this BIOS string is a Chicony MP995 notebook. Chicony built laptops for other people but no longer support them.
Some info is available at http://www.orphanlaptops.com/chicony.htm
I can find and patch the same BIOS you have;
BIOS ID string: 02/11/2000-BANISTER-2A69NC2AC-00
BIOS OEM string: V1.17 02/11/2000
found at http://www.databest.fi/mp995dwn.htm which has drivers as well.
I'll send that patched BIOS to you in a short while.
harrylette
as you you have seen, I have already applied this patch. I know this sh*t with chicony, so yesterday I posted a request at orphanlaptops.myforum.net. But I do not think that they can help me. Makes it sense to buy a BIOS at eSupport.com?? Because I think that they do not know Chicony's hardware architecture.
Thanks a lot
Harry
Thanks a lot
Harry
harrylette
I did not read your message exactly... Sorry. I received your eMail and will immideately try to flash my bios.
I will use this command from my bootdisk:
awdflash 995V117x.BIN /cc /cd
Is this right?
Thanks a lot
Harry
Is this right?
Thanks a lot
Harry
harrylette
Yo man!
Thx!
The patch has worked!
Know I can install my system of choice- FreeBSD NetBSD windows and Linux on one notebook! Juhuu!
Can I send the patched BIOS to my hardware vendor (MaxData) that they probably put it on their ftp?
Harry
Thx!
Harry
You can tell them the bios will show up at http://http://wims.rainbow-software.org
Because my hard disk crashed and windows XP/2000 never worked great with ACPI, I am planning to update the bios (1.11) of my MP995.
However, I have to choose between:
I don't know if it was hard to patch this bios, so I don't know if I can ask this to you guys, but wouldn't it be great to combine the 2 fixes in 1 patched 1.17.1 release
Thanks a lot!
- The patched 1.17 from this thread, which will support my new hard disk (planning to buy a 60GB)
- The 1.17.1 from a russian site, which was mentioned in this thread to make ACPI function correctly
Thanks a lot!
Patched BIOS sent.
