I have no idea of what to do next and could use any help or ideas.
80GB: Microstar (MSI) MS6119
marvin51796
I am trying to install a 80G WD hard drive, and i have it patched up to the 2.a version that supports drives over 64G and has a date of 08-21-2000 on it. The problems is that once i connect this drive as primary or slave the system boots , sees the drive and then locks up after it goes thru the disk search.
Do you have drive jumpers set properly? If the drive is the only device on the cable, it must be configured as single, not master.
marvin51796
Yes i have the jumpers set right, i have set it as the primary master, i have set it up as the primary slave with a 4g HD as the primary master. I have chosen the cable select setting....everything that the book has said i have done..
marvin51796
Well i was able to get the bios tricked into seeing the HD, and once it saw it I was able to load the software that came with it and XP saw it then.
Thanks to everyone for all the help i was so lost.
