I need a bios update so i can use my 80 gig hd i bought, The bios i have now only lets me goto 33gigs.
Here are the specs on my pc..
BIOS Date: 10/20/98
BIOS ID: 10/20/1998-i440BX-W977-2A69KM4AC
OEM Sign-On: W6119MS V2.7 061499
Chipset: Intel 440BX/ZX rev 3
OS: Win2000
CPU: Pentium II 450 Mhz MAX: 450 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 256 MB
Memory Maximum: 96 MB
Memory Slot 01: 128 MB
Memory Slot 02: 128 MB
Memory Slot 03: 0 MB
80GB: 10/20/1998-i440BX-W977-2A69KM4AC
It appears you have an MSI MS-6119 motherboard with BIOS version 2.7 which has an "Update date" of June 14 1999.
It is probably the "MSI Standard" version of the motherboard rather than the "CPU Plug and Play" version. There are different BIOS's for the different versions of the motherboard.
http://www.msi.com.tw/program/products/ ... hp?UID=105
The newest BIOS version for this motherboard is s2.a which recognizes HDs up to 128 GB.
