Need the bIOS update for drives above 20G if anyone knows where to obtain it. It is a PC Chip Motherboard running a Celeron Processor. Ami BIOS Vers 1.2 02/07/2001
Gayle
20GB+: 62-0914-009999-071595-000000-M748LMRT need update
The actual Boot code it gives is AMi BIOS version 1.2 09/14/1999S
The Version I gave you was one given via the AMI BIOS Identification program which ended up not recognizing the project tag for the BIOS. (which was TG_M748LMRT.) This is only a Celeron 333 MHz.
The MFG ID 009999 I believe is PC Chips but the Chipset / BIOS information is 000000. It is a SIS 530/620 Chipset and the Windbond code if helpful is 29C020-02
Gayle
The Motherboard is actually the M748LMRT-H (left out the H when typing)
Gayle
