the present bios doesnot detect hdd >32gb, can anyone provide me with the update to this bios.
BIOS ID: 2A69KF0EC
BIOS DATE: 10/15/99
SIGNON: 10/15/1999-i440BX-W977EF-2A69KF0EC-00
TYPE: Award Modular BIOS V 4.51PG
Chipset: Intel 440BX/ZX rev 3
OEM Signon: Version MZ4225
40GB: 10/15/1999-i440BX-W977EF-2A69KF0EC-00
Looks like FIC KBI-6130.
Plasma-Online suggests so but the Bios/PCB version indicator "MZ" is not shown at FIC - KBI6130 has MK or MRRainbow wrote:Looks like FIC KBI-6130.
Might be a very special version for Compaq/HP or similar companies
It's seems to be a special version for Compaq with support only from Compaq - FIC Bios does not work !shobhitj wrote:its a Compaq Presario 100p, can i flash award mi415 BIOs on it?
Please have a look at your mainboard and tell us model number and revision number !
Have you lookde at Compaq ? > Mybe they have a newer Bios
http://www29.compaq.com/falco/sp_detail ... eVer=12090
10/28/1999
There is a slight chance this one might do the trick...
10/28/1999
No that is not going to work. Compaq has done something horrible to their version which trips our standard patch for >32GB support so we'll have to try another method.
Please have a bit more patience.
The description of this bios says:
Version MZ4225 128GB BETA apple_rom patch
but its an intel pentium III-450mhz, not an apple pc!!! so is it ok to flash with this version.
if its ok plz also tell me the version of flash that i shud use to flash it.
apple_rom is the nickname of the person writing the patch. Any 6.x version of awdflash should work, you can even use the one from the compaq Rompaq disk.
