i am in a big problem with my mother board epox mvp4f
i brought a new maxtore 80.0 g.b
but my mother board dosn't recognize it
if any one can help me upgerading my m.b
plzzzzzzzzzzzz
thanx for this great forum
80GB: epox mvp4f
vp4f1313.bin at http://www.epox.nl appears patchable:
BIOS ID string: 03/13/2001-VP4-686A-2A5LHPA9C-00
BIOS OEM string: 03/13/2001 For Apollo MVP4 AGP/PCIset
but not >64GB, as
Searching for size calculation routine...Found at 2327
Patching code at 2326
Patched...will email
but not >64GB, as
Did you clear the CMOS after flashing ?toty2k wrote:thank you but i am afraid that it doen't work
in this case can you tell me how i can repaire it
or reflash the bios again?
Were there any error messages during flashing ?
Does anything appear on the screen now ?
No, but we try harderNicks you are the best
Clear the CMOS and see if it makes any difference. Unplug the power at the wall, carefully remove the battery from the motherboard and leave for 10 minutes. If you can short-circuit the battery contacts for a minute, do that also. Re-insert the battery and see if this has made any improvement.
If this does not work, you will need to look at the options for "My board is dead" in the main Wimsbios site FAQ. The MVP4F has no ISA slot so you cannot use an ISA video card or FDD card. If you have access to another board with a 32-pin socket you may be able to hot-flash the original BIOS.
(In the worst case, with Epox there is the option to buy a replacement BIOS.)
ok i have Acorp 6bx/via/zx86 motherboard working
can i hot flash ?
please tell me the detalied instruction on how to hot flash my epox motherboard with the working mother board
i cleared the cmos but nothing happen
thank you for your co-operation
thank you
can i hot flash ?
thank you
