I like to install a new HD of 90GB.
Probably my bios is not regonizing my HD.
I cannot find the exact upgrade for my Bios, can somebody help?
Bios type: Award Modular BIOS v4.51PG
Bios Id : 12/10/1998-i440BX-DD-2A69KD42C-00
Chipset: Intel 440BX/ZX rev 3
OS : Microsoft Windows 2000 Version: 5.0.2195 Service Pack 4
CPU Type : Pentium® III (0.25 µm) 451 MHz
Many thanks in advance.
With kind regards
murpje
90GB: 12/10/1998-i440BX-DD-2A69KD42C-00
Murpje1999
Edwin,
I opened my Pc but was not able to find the information you asked.
Are there other options to find out.
grtx's Murpje
grtx's Murpje
Murpje1999
I found some extra information regarding my Pc..
It's mentioned below.
PCI IRQ Routing Table : BIOS currently supports this feature Enhanced Disk Drive
Specification : BIOS doesn't support this feature
DMI Version:Current version is 2.0. The minimum DMI version is 2.1
ACPI Version : BIOS currently supports latest version 1.0
BIOS Chip in Socket : BIOS currently supports this feature
Supports LS-120 Booting : The testing of this feature is not supported by the current DMI version
Supports ZIP Booting : The testing of this feature is not supported by
Supports Network Booting : The testing of this feature is not supported by the current DMI version
BIOS ID : 12/10/1998-i440BX-DD-2A69KD42C-00
BIOS Date : 12/10/98
BIOS OEM Signon :
BIOS ROM Size : 256K
Chipset : Intel 440BX/ZX rev 3
Super I/O Chip : Winbond 83977EF found at port 3F0h
BIOS OEM Signon :
Might be written onto the motherboard between the PCI Slots - please have a closer look
Revision number might be of interest if there's any - DFI usually uses A,B,C etc as Revision indicator
Murpje1999
I found some, I hope more usefull information:
some chips on my motherboard.
Intel: PCI Set
FX82371EB
F850IG46
SL37M
Intel '98
and
Winbound
W83977EF-AW
AM Mega 87-96
841a2b283195802
and
Award PCI PNP 682
S/N 153588370
1998
Hope it's helpfull for you..
grtx's Murpje
Intel: PCI Set
FX82371EB
F850IG46
SL37M
Intel '98
and
Winbound
W83977EF-AW
AM Mega 87-96
841a2b283195802
and
Award PCI PNP 682
S/N 153588370
1998
grtx's Murpje
Look at the picture !!
-> Model number is printed onto the board next to the AGP connector
Please have a closer look at anything what's printed onto the mainboard and not onto the chips
It seems this board was used in OEM-systems (Yakumo and others) so there might be a sticker covering the model number
Murpje1999
I found only one of it.
P2Xbl REV C
The motherboard shown on the picture is identical ( let's say the look of it)
Do you have all information for now, if not can you point out on the picture where I can find the AGP connector.
thanx's Murpje
P2Xbl REV C
thanx's Murpje
For P2XBL revision B & C:
supports disks up to 128GB.
http://www.dfi.com.tw/Upload/BIOS/P2XBLBJ.ZIP07/20/2000-i440BX-FD-2A69KD42C-00
Murpje1999
Thank's
I will try to update it...
You will hear from it...
grtx's Murpje
grtx's Murpje
Murpje1999
I downloaded the file.
How to handle it from here.
I tried to start up from a floppy disk and to start the program.
I succeeded in that. What to do next ?
grtx's Murpje
btw edwin, if it's easier put your remarks in dutch. I can read it.
grtx's Murpje
Murpje1999
Search on the internet for instructions.
It's workin.... Thank guys.
Vielen Dank,
Hartstikke bedankt.
greetings,
gruessen,
groeten,
Murpje
Vielen Dank,
Hartstikke bedankt.
greetings,
gruessen,
groeten,
Murpje
