Hello, I need an update for this bios in order to install a new HD 80 GB. This are the specifications
BIOS Date: 02/23/99
BIOS ID: 02/23/1999-i440BX-SMC60X-2A69KB0CC
OEM Sign-On: TBA0224B
Chipset: Intel 440BX/ZX rev 3
Superio: SMC 60x rev 0 found at port 3F0h
OS: WinXP
CPU: Pentium III 450 Mhz MAX: 550 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
80GB: 02/23/1999-i440BX-SMC60X-2A69KB0CC
Should be a BIOSTAR M6TBA board.
A patched BIOS version is here:
http://wims.rainbow-software.org/
Make sure your board revision is V1.2 or below.
The upgrade that you say is not for rev 1.3 of this motherboard, that indeed is M6TBA.
the problem is that the OEM number is not the same (TBA0224B).
I'm not sure that this upgrade would be the good one.
Thank you
Thank you
Now you understand the benefits of providing us with ALL of the information you have
OK, the BIOS you need is:
http://www.biostar.com.tw/products/main ... a1124b.exe
11/24/1999-i440BX-SMC60X-2A69KB0CC-00
TBA1124B
Our utility states:
"BIOS already supports HDDs over 32GB & 64GB"
NOTE: The OEM message changes because BIOSTAR includes the month and day of the release as part of it.
TBA1124B
Our utility states:
Create a DRDOS bootdisk from www.bootdisk.com
I've flashed the BIOS version with the upgrade and I've installed win XP, but a the end, when you restart, the system shows a black windows and stop.
When the instalation is in progress the system recognize the HD capacity and the bios always recognize the HD, but I don't know which is the problem.
Thank you for all your useful help. In other way in would not be posible to actualize my BIOS. Finally the system is working fine. The last problem was a simple monitor resolution problem.
This forum is extremely useful, due to people like you.
I'm in debt with you.
Best regards
Have a nice day
Best regards
Have a nice day
