The BIOS in my older P3 does not recognized my recently purchased 40GB drive and I could find a BIOS that I could flash. Can you guys help me out ?
my data bios :
BIOS Date: 04/06/99
BIOS Type: Award Modular BIOS v4.51PGM
BIOS ID: 04/06/1999-i440BX-ITE867-2A69KH2BC-00
OEM Sign-On: (661ZS141) Intel i440ZX PCIset(TM)
Chipset: Intel 440BX/ZX rev 3
Superio: ITE 8671 rev 1 found at port 279h
OS: Microsoft Windows 98 SE Version: 4.10.2222 A
CPU Type: Pentium III
CPU Speed: 450 Mhz
CPU Max: 900 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 128 MB
Memory Maximum: 256 MB
Memory Slot 01: 128 MB
Memory Slot 02: 0 MB
Many many thanks
koby
40GB: 04/06/1999-i440BX-ITE867-2A69KH2BC-00
Holco/Shuttle/Spacewalker board.
Follow the instructions here:
http://www.shuttle.com/hq/support/download/download.asp
HOT-661Z V 3.x (BIOS 661Z141)
Problem is, there is no BIOS on the site for HOT-661Z, only for various HOT-661 and HOT-661V models.
Comparison at:
http://de.shuttle.com/mb_slot1_atx.htm#atx_format
You may wish to take a back-up of your BIOS so that we can patch it if we can't find an up-to-date BIOS.
Comparison at:
Aha! That should do nicely, then.ajzchips wrote:I have a feeling the 661 and 661z use the very same BIOS. The newer BIOS releases include the "Intel 440BX/ZX AGPset" message in the BIOS message.
Apologies for double posting, I'm having trouble with the firewall
