Hi
I need a patch for the 32Gb Bug in the award bios
Here go my details:
BIOS Date: 02/10/00
BIOS ID: 02/10/2000-693-596-W977E-P6BAT-APC-00
OEM Sign-On: P6BAT-AP Ver 5.4 02/10/2000
Chipset: VIA 82C691 rev 68
Superio: Winbond 977EF rev 4 found at port 3F0h
CPU Type: Pentium III
CPU Speed: 550 Mhz
CPU Max: 500 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 128 MB
Memory Maximum: Unknown
32GB+: 02/10/2000-693-596-W977E-P6BAT-APC-00
A patch would be too easy... you'll have to do your homework first
ftp://ftp.ecs.com.tw/bios/p6batap56.exe
You're using BIOS version 5.4; the link provided is version 5.6:
06/22/2000-693-596-W977E-P6BAT-APC-00
P6BAT-AP Ver 5.6 06/22/2000
Our utility mentions (for 5.6): "BIOS already supports HDDs over 32GB & 64GB - Nothing to do!"
[quote="ajzchips"]A patch would be too easy... you'll have to do your homework first
Thank you very much!
This update has really worked, in a few minutes I've reached the version 5.6.
Oops...It was the little jumper.I've removed it and now I'm working with 120 GB. I have to admit if wasn't the forum I never would see my problem resolved. Thank once more!!edwin wrote:remove the 32GB limiting jumper from the harddisk...
It's a good thing I'm visiting these forums very often else I would have been bitten by this as well at some point in time.
