Hello everybody,
I'm searching for a recent (preferrably the latest published) version of IBM's/Hitachi's DiskManager 2000 - they unfortunately have removed this tool from the download site @ www.hgst.com, "because systems with Windows XP and 2000 don't require it" (which is only half true - how can the operating system come up when the BIOS chokes on the drive's size and refuses to work?).
So if anybody out there has a version of this tool, i'd be very happy to hear from you - I'll send you a PN with my eMail adress then.
Thanks a lot,
Aragorn
Wanted: IBM/Hitachi DiskManager 2000
Tried using the Feature Tool to change the reported size to 33.6GB ? That should make it possible to boot the installer, and is part of what the Disk Manager did in recent versions. Alternatively, turn off the autodetect and set the drive up manually (I remember setting up 48MB drives as 10MB to load DM 3.1 on a 286 system).
Here's the Link I gave you :
http://service.boulder.ibm.com/storage/ ... m_2000.exe
With thanks to www.station-drivers.com
Just in case someone needs this software,too
