Hi
system below doesn't detect 80GB Maxtor HD even after having flashed patch. Hope you can help me.
BIOS ID: 04/20/1999-SiS-5600-2A6ILP8AC-00
OEM Sign-On: 02/23/2000 6SBTW FOR PT-6SBT (Y2K READY)
Thanks in advance
Luigi Riccoboni
80GB: 04/20/1999-SiS-5600-2A6ILP8AC-00
What are the symptoms ? Hang at "Detecting..." or hang at configuration display screen ?
And you used the BIOS from http://wims.rainbow-software.org/ ?
That has been tested with 60GB but not with >67GB AFAIK
If this is the BIOS you used we will have to try a different patcher for your drive.
OK, I'll take a look.
