06/22/98-i430TX,ITE8680-2A59IH2EC-00
565WIQ0G Intel i430TX PciSet(TM)
HOT-565 Shuttle Spacewalker
Maxtor 40GB
ftp://ftp.shuttle.com/BIOS/565/
Thank you!
40GB:06/22/98-i430TX,ITE8680-2A59IH2EC-00
Somebody can help me please?
Others precisions : 3 tests failed and 3 (!)
Enhanced Disk Drive Specification : BIOS doesn't support this feature
DMI Version : Current version is 2.0. The minimum DMI version is 2.1
ACPI Version : ACPI is not found
Supports LS-120 Booting : The testing of this feature is not supported by the current DMI version
Supports ZIP Booting : The testing of this feature is not supported by the current DMI version
Supports Network Booting : The testing of this feature is not supported by the current DMI version
My link to shuttle ftp work, it's just slow.
Thank you
Thank you
Patched for support upto 64GB, since it's safer than upto 128GB when your BIOS is pre-1999.
Your same version has been patched, since it is the most recent.
Check my signature for the update.
