Hello,
I wanted to connect a 40 GB Maxtor drive to my Settop-Box, but it failed to recognize.
Can you help me out?
Bios Agent provided me with the following informations:
Program: eSupport.com BIOS Agent Version 3.30
BIOS Date: 11/04/99
BIOS ID: 11/04/1999-GXm-Cx5530-2A434H09C
OEM Sign-On: WebSurfer Bios V0.9 Hacked with floppy support 1999/02/23
Chipset: Unknown
Superio: Unknown
OS: Win98
CPU: Cyrix MediaGXtm MMXtm Enhanced 180 MHz
BIOS ROM In Socket: Unknown
BIOS ROM Size: Unknown
Thanks in Advance
Helmut
40GB: 11/04/1999-GXm-Cx5530-2A434H09C
Checking.....
BIOS with 64GiB bugfix emailed - please let us know whether it worked OK.
The H0 manufacturer code should be PC Chips...Interesting...
Thanks for the feedback... can you tell us what make/model your box is so we can list it ?habee wrote:Wow, great job!
It works!
Thanks a lot
It is a Set Top Box build by Allwell (http://www.allwell.tv, the type is 1030N.
This Box is oem-build by different distributors, so it´s sold as
- Mobilcom Surfstation
- Websurfer Pro
- Easynetbox
Here are some pictures:
http://www.fli4l.de/gallery-1.4.3/surfstation
I have a second one which I want to set up as Mp3-Box, so I needed the Patch.
Bye
- Websurfer Pro
- Easynetbox
Bye
Hi all,
I've got the some box, the same board and the same problem
Is there a place where I can download the patched BIOS? If not, could someone please send it to me?
Final question: would I be allowed to make the patched BIOS available to a greater public?
Cheers
Phileas
http://www.dabo.de/surfstation/
Cheers
Phileas
You can find it at the "untested" link in my signature under the name "websurfer.zip". Feel free to post it on your site, but please credit Wim's.
