my ms-6159 mobo will not recognise the 80gb maxtor hdd i am attempting to install as a slave.
my bios string is as follows:
61-0413-001169-00111111-07159-440LX-1440L000-H
it is an ami bios
the master is another maxtor hdd of 8GB capacity.
The large hdd appears in the os (winxp pro), but not in the bios which is set to AUTO .
MSI germany has bios v1.6 but other sources only v1.2.
Unit will not post if larger hdd is set to slave, but will post if set as slave with a limit of 40gb with appropriate jumper setting (cvl or clv whatever)
any help greatly appreciated.
NTFS used.
80GB: ms-6159
v1.6 bios successfully installed
post screen sees 65GB of hdd but it does not
appear in My Computer at all only the 8.4gb hdd master.
appears in Device Manager but not seen when Everest
utility is used.
any further suggestions appreciated.
utility is used.
