i have a little problem. I installed a second HD (80GB) but WIN XP only identifikated 32GB. I have searched for a knew Version of my BIOS but i couldn´t find anyone.
My Parameters:
BIOS TYPE: Award Modular BIOS v4.51PG
BIOS ID: 09/08/2000-693-596-8671-2a6lgc3fc
Chipset: VIA 82C691 rev68
On your homepage i read thats possible that you and your team can modified a BIOS Version, so that the HD identified completely.
Is that possible?? Plaese help me!
thanks for all that you are doing for me.
respects
Savas Gör
80GB: 09/08/2000-693-596-8671-2a6lgc3fc
Hi,ajzchips wrote:Check whether you have your capacity-limiting jumper on.
sorry but I´am a NOob and the other problem is, my english is bad. I can´t understand everything.
It´s possible that you can specify how i have to do it or what exactly i have to do.
Please , please help me...
Thanks and best regards
Savas
If you check the jumper settings for your HDD, you will most probably one that limits the cylinders (reduces the total recognized size) to 32GB. It might still be on, so you'll have to remove it.
ajzchips wrote:If you check the jumper settings for your HDD, you will most probably one that limits the cylinders (reduces the total recognized size) to 32GB. It might still be on, so you'll have to remove it.
i´am so sorry, i´am so silly. Yes i found the mistake, yes you´re right. the jumper setting was only able to 32GBG.
thanks....
