hi im blaine
my bois id is 52-1028-001437-00101111-071595-000000-001_01_m598lmr-h
American Megatrends AmBios
10-28-1999s
i tirck the bois to read my 80gig i think by doing so it lags the comp. not sure though
i know i has a sis530 shipset and it has davidcom lan
i think this is the borad m598lmr 1isa 2pci amd k6-2 500cpu
i got from this site pic of it here
http://www.stud.fernuni-hagen.de/q39981 ... 598lmr.gif
Thia is the sit i got it from http://www.stud.fernuni-hagen.de/q39981 ... /pccout.sh
if you need more info just let me know
80GB: 52-1028-001437-00101111-071595-000000-001_01_m598lmr-h
It sounds like you could do with a newer BIOS. Do you have PCB V1.3, V5.0 or V6.0?
Download the latest BIOS for your board from [url]http::/go.to/ajz[/url]
You may have to reduce the max UDMA mode, using the disk manufacturer's utility, to prevent hanging when you load Windows.
Don't forget your version of FDISK and Windows must support the size of partition you are trying to make - if you are using Windows 98 you may have to download a new version of FDISK from Microsoft.
