I tried to install a WD 80GB, and the BIOS just locks up at detect.
Is there a fix for this anywhere?
Thanks!
db
80 GB: 08/06/98-i440LX-P2L97-S-00 ASUS P2L97-S
I don't see any betas for the ASUS P2L97-S BIOS
Here's the BIOS dump:
BIOS CAPABILITIES TEST REPORT
Date: February 16, 2005
Time: 10:08
Enhanced Disk Drive Specification : BIOS doesn't support this feature
DMI Version : Current version is 2.0. The minimum DMI version is 2.1
ACPI Version : BIOS currently supports latest version 1.0
BIOS Chip in Socket : BIOS currently supports this feature
Supports LS-120 Booting : The testing of this feature is not supported by the current DMI version
Supports ZIP Booting : The testing of this feature is not supported by the current DMI version
Supports Network Booting : The testing of this feature is not supported by the current DMI version BIOS Manufacturer : Award Modular BIOS v4.51PG
BIOS ID : 08/06/98-i440LX-P2L97-S-00
BIOS Date : 08/06/98
BIOS OEM Signon : ASUS P2L97-S ACPI BIOS Revision 1005
BIOS ROM Size : 256K
Chipset : Intel 440EX/LX rev 3
Super I/O Chip : Winbond 83977F/AF found at port 3F0h
Time: 10:08
Denniss,
Thank you so much!
I also found the U.S. version of the same file and flashed it. (There was a one byte difference in file size between locations, which likely means nothing)
I am now ghosting the old drive to the 80 GB.
Thanks Again!
best regards,
db
Thank you so much!
Thanks Again!
best regards,
db
