This is all the info I get:
BIOS Date: 03/04/99
BIOS ID: 03/04/1999-i440BX-W977TF-2A69KF09C-00
OEM Sign-On: Version MI412
Chipset: Intel 440BX/ZX rev 3
Superio: Winbond 977EF rev 1 found at port 370h
CPU Type: Pentium II
CPU Speed: 400 Mhz
CPU Max: 500 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 320 MB
Memory Maximum: 1024 MB
Thank for the help all...
40GB: 03/04/1999-i440BX-W977TF-2A69KF09C-00
Looks like FIC VB-601
Check whether you have version 1.3 or 1.4 of the PCB. If you have version 1.3 it looks like you need a patched BIOS. If you have version 1.4 you may or not depending on the I/O chip.
BIOS Page
FAQ.
BIOS Page
FAQ.
ftp://ftp.fic.com.tw/motherboard/bios/s ... MI4118.ZIP
The latest Bios - should not require a patched Bios for large HDD
Revision number matches - look at the Bios version description MI412 and MI4118 - other Revisions have ME or MC instead of MI
So just use the bios that you linked above in your post Denniss? I noticed by the 5th PCI slot that I do have MI412(5) (put that in because the 5 isabout 1/2 the size of other chars). Oh, and it is a VB-601 board.
