Hi
Can't use my 80GB Samsung HDD
BIOS Date 12/23/98
BIOS Type Award Modular 4.51 PG
Serial Number 12/23/1998-ITE8671-2A69JV3FC-00
Pls help
Michael
80GB: 12/23/1998-ITE8671-2A69JV3FC-00
VTech/PC-Partner LXB834D/LXB843D/EXB831D/EXB841D (ITE 8671 I/O)
There are a patched Bios for it :
http://wims.rainbow-software.org/nicks/ ... 0128KB.zip
michaeldeepan
Thanks for the Instant reply. This is a report generated by SIS Sandra Soft
System BIOS
Manufacturer Award
Version Award Modular BIOS v4.51PG
Date 12/23/98
Plug & Play Version 1.00
ID No. FC 01 00
Processor(s) Intel Celeron 418MHz
Performance Rating PR502 (estimated)
L2 On-board Cache 128kB ECC synchronous write-back
System Bus(es) ISA(16-bit), PCI(32-bit), USB, AGP(32-bit)
System BIOS Award Modular BIOS v4.51PG
System Chipset Intel 82443LX/EX Chipset, CPU to PCI Bridge
Installed Memory 64MB (134% true allocated load)
Extended Mainboard Data
Manufacturer VTech
Name BIOS-I (81223)
Chipset Intel 440LX Chipset
System Chipset
Front Side Bus Speed 84MHz
CPU Speed Multiplier 5x
Will Patch file work on this. Sorry to bother you
Thanks again
Michael
System BIOS
Manufacturer Award
Date 12/23/98
ID No. FC 01 00
Manufacturer VTech
Name BIOS-I (81223)
System Chipset
Thanks again
Michael
Yes, is a tested BIOS from Nicks:michaeldeepan wrote: Will Patch file work on this. Sorry to bother you
Thanks again
Michael
michaeldeepan
Thanks Buddy, It worked
Can U recommend other utililty prog.
Cheers,
Michael
Cheers,
Michael
