BIOS ID: 07/26/1999-i440ZX-W977-2A69KA1QC-MT
ABIT ZM6 motherboard..
80GB Maxtor hard drive
The bios does not recognize the harddrive, after setting the jumper to limit the size, I could only use 32 GB.
Would like to fully use my 80 GB..
any help is highly appreciated!
80GB: 07/26/1999-i440ZX-W977-2A69KA1QC-MT
does the lastest bios support 80G harddrive? there is no explanation, only a previous version supports 40G...
there is no the patched and tested bios update for ABIT ZM6 board.
any suggestion please.
Help.....................
Denniss,
By any chance you have a updated bios for my ZM6?
I will try your suggestion of testing the lasted ZM6 bois version, will let you know the result.
what is uniflash? can I use it?
Thank you in advance.
Uniflash is a universal flash utility.
Please use the flashprog Abit suggests to use or Uniflash to update your Bios.
If the latest Bios does not cure your problems then one of the mods will try to patch the latest Bios for you.
Help .... Please...
Updated BIOS to the lastested version, zm6_su.. as it says.. supporting to up to 40GB hard drive... but I still can not fully use my 80GB drive...
anyone can help this out? Thank you very much.
