hello my pc not reconiz my hard drive 80GB WD.
02/02/2000-ALADDIN5-2A5KKF9BC-00
FOR AGP-ALI PCI/ISA/AGP VER:3.3_66
ALi M1541 rev 4
Microsoft Windows XP Version: 5.1.2600 Service Pack 2
thx for the help
80GB: 02/02/2000-ALADDIN5-2A5KKF9BC-00
Originally Fordlian/Redfox, but later taken over by ACORP using model 5ALI61:
http://www.acorp.com.tw/eng/download/do ... 7&lineid=1
BIOS ID string: 02/02/2000-ALADDIN5-2A5KKF9BC-00
BIOS OEM string: FOR 5ALI61 PCI/ISA/AGP VER:3.3_66
BIOS already supports HDDs over 32GB & 64GB
It's your same release... so you'll have to insert the HDD parameters manually.
If it's only recognized as 32GB then check HDD manual where the 32Gb limitation jumper resides and remove it.
It it's not recognized at all via Bios check HDD cables and Master/Slave jumpers.
If it does not show as drive with a driveletter assigned make sure it's patrtitioned and formatted
