hi i am in a broblem i have a hdd 80 gb it's not readable please help this is my hdd details :
bios type: Award Modular BIOS v4.51PG
bios dtae: 10/11/00
bios id: 10/11/2000-i440BX-W83977-2A69KTG9C-00
oem sign-on: TRM-P6BX-A4X v1.10
chipset :Intel 440BX/ZX rev 3
Pentium® II (0.25 µm)
please help as soon as u can
thanx too much
80GB: i440BX-W83977-2A69KTG9C-00
Patched BIOS for Tekram P6B40-A4X, courtesy of Rainbow:
http://wims.rainbow-software.org/rainbo ... 40-A4X.zip
Hola desde España (Sevilla), no se hablar ingles, perdon. Yo tengo esa misma placa con trm-p6b40-a4x-v1.10 y actualizado 10/11/2000-i440bx-w83977-2a69ktg9c-00. y no soporta usb 2.0, ayuda para actualizar a amyor version. Gracias si podeis ayudarme.
Hello from Spain (Seville), not to be spoken ingles, pardon. I have that same plate with trm-p6b40-a4x-v1.10 and updated 10/11/2000-i440bx-w83977-à69ktg9c-00. and he does not support usb 2,0, aid to update to amyor version. Thanks if podeis to help me.
USB is a hardware limitation. You can't upgrade USB 1.1 hardware to USB2.0 only with Software. USB 2.0 stuff will run at 1.1 controllers but only with 1.1 speed. Try to find a USB2.0 controller card for PCI-Bus
