Intel(R) Celeron(TM) CPU 1200MHz (Tualatin)
overclock 1600.01 MHz (133*12, overclock: 33%)
Seagate 160G HDD
IBM 41G HDD
320M SDRAM
Windows Server 2003, Enterprise Edition SP1
used BIOS PATCHER 4.23
Look for BIOS update for 48 bit LBA & ACPI support Windows XP/2003
BIOS ID: 03/23/2001-694X-686B-6A6LJPRAC-00
After USED BIOS PATCHEER 4.23 BIOS ID CHANGE TO
10/10/2003-694X-686B-6A6LJPRAC-00
HELP 160G for 03/23/2001-694X-686B-6A6LJPRAC-00
PcPartner mainboard, maybe an OEM version. http://www.pcpartner.com
PcPartner motherboards should have a PCb version printed onto the board, a combination of letters and numbers, go to the VIA 694X Bios update page and verify what your board is.
If your board does not support native 48BitLBA adressing then your OS should do. http://www.48bitlba.com
