hello,
sorry my bad english. I have updated to Maxdata Bios all three versions.
The Board say 8 GB is in. When i jumper the WD compatibily he say 33 GB is in the Board.
Then I played your D51IDE Bios on the board. The board can no HDD found.
With compatible WD jumper he found 33GB HDD.
You say 128 GB must found. What is wrong????
P.S. : WD 1600 JB HDD
MS6151- Biosupdate not work
Try using AppleRom's BP utility... http://rom.by
160GB >128GiB - not supported. You can use a utility to reduce the reported size of your HDD to 128GiB, e.g. http://www.hdat2.com/ then it should work with our patched BIOS.DonCaputto wrote:P.S. : WD 1600 JB HDD
