Hello Experts!
New 80GB IBM/Hitachi Harddisk - BIOS can not recordnize it!
Could anyone please help me and send a Patch to me with a BIOS-Update, that i can use this new Harddisk?
PC: Maxdata
Mainboard: MS6119 Ver. 1.2 BX2
*** Further Infos to BIOS ***
BIOS Date: 03/31/00
BIOS ID: 03/31/2000-i440BX-W977-2A69KM4AC
OEM Sign-On: VMP 1.0B9b * MSI MS-6119
Chipset: Intel 440BX/ZX rev 3
OS: WinXP SP1
CPU: Pentium® III (0.18 µm) With 256 KB On-Die L2 Cache 651 MHz
THANX A LOT!!!!
Juergen (hausl78)
80GB: 03/31/2000-i440BX-W977-2A69KM4AC-00
This is an MSI (MicroStar) motherboard OEMed by Maxdata. I'll see what can be found, but meantime maybe you would like to save your existing BIOS, zip and email it to me? Put "Wim's BIOS" at the start of the subject line to avoid being discarded as spam.
I looked at a BIOS for the generic MSI MS6119 V1.2 a while back.
I guess it could be patched with apple_rom's patcher...MSI MS-6119 v1.2 (MS-6119 CPU PnP) BIOS
OEM message: W6119MJ V2.9 120100 patched for HDD to 128 Gb
BIOS ID: 08/03/2000-i440BX-W977-2A69KM4AC-00
This patch does not correct hang-up problems with Standard CMOS Setup and IDE Autodetect menu. You may have to disconnect your HDD to enter Standard CMOS setup.
I suggest you create a basic bootable DOS diskette from an image ("Driver free disk for BIOS flashing") at http://www.bootdisk.com/ and use Uniflash to read out the binary.
Thank you! I will send you the BIOS the next few days, because the PC belongs to a friend of mine, may be i can do it tomorrow.
But I already have downloaded the both programms and created the Bootdisk
thanks / greets!
juergen
thanks / greets!
juergen
Patched MS-6119 OEM BIOS (beta) for Maxdata/Vobis:
http://wims.rainbow-software.org/kuriak ... bis%29.zip
THANK YOU KURIAKI, that was speedy!!
And the chance that the board (Ver. 1.2 BX2) will not be destroyed after flashing are good
- although its "beta"?
Now i need a Bootdisk (eg. the one that was created from the Link above (NickS) and copy the AWDFL757.EXE and the 10B9B_19.IDE on the disk.
In the Flash-Programm i use then the 10B9B_19.IDE File for updating.
Is this the correct way?? The .IDE File has 256KB, i think the Original has 128kb - ist this a problem?
Thanks a lot, i will inform you about the results!!
Juergen (hausl78)
Juergen (hausl78)
The original has 256kb too:
http://ftp.maxdata.com/index.asp?info=/ ... ds/MS-6119
... and this equals to
http://www.supportbios.info/modelo.asp? ... &Idioma=EN
ok, so i understand!
I'll try it to flash and inform you if it is works correctly (othierwise i'll have to beg for your help again
THANK's
Juergen
THANK's
Juergen
