I have a Biostar motherboard
Bios date 06/16/00
Bios Award modular BIOS v4.51PG
Award ID-string i440ZX-SMC60X-2A69KB0JC-00
OEM Sign-On TZA0616D
Superio: SMC 60x rev 0 found at port 3F0h
chipset: i440ZX-SMC60X // Intel 440BX
I want to put a 40gb harddisk (WD400) in it but its not recognised.
Could you please inform me where i can find the Bios update and which flashprogram i can use best?
I couldnt find anything on the website of Biostar.
thanks in advance
My award bios doesnt support a 40gb disk
not recognized - check your cable connection or HDD positioning at the cable and/or the Master/Slave/CS/single-Master jumper settings.
Especially WD loves to be Sibngle-Master if no slave drive is present on the same cable.
With a Bios error regarding HD detection the Bios should freeze or display totally wrong numbers.
psycho_groupie
I had it autodetected, havent done the manually setting.Are you having it autodetected? Have you tried setting the parameters manually?
I have tried the disk as master as well as slave, both options failed.check your cable connection or HDD positioning at the cable and/or the Master/Slave/CS/single-Master jumper settings.
I am afraid that maybe the secondhand disk is the problem, i will try to connect it in another computer this evening and see if it is recognised then.
Maybe the bargain wasnt a bargain after all
psycho_groupie
I had to take the jumper from the "master' setting, so didnt have to use the jumper at all.
You were right, thanx a lot.
Thank you all, you are doing an outstanding job here, much appreciated.
