Hi
I've got a PC with an Award Modular BIOS v.6.00PG (BIOS string: 08/17/2001-P4X266-8233-6A6LWE19C-00). It works fine with Win 2000, but it doesn't boot with Win XP Home SP2 (STOP: 0x0000007B; inaccessible boot device).
Do I need to upgrade the BIOS? If yes, where can I get it from?
Thank you for help.
Award Modular BIOS v.6.00PG and Win XP
Incomplete BIOS ID.
Can be an ECS P4VXAS or P4VXMS.
Run BIOS Agent and send us your BIOS report please:
http://www.unicore.com/biosagent/index.cfm
This is from ctbios:
OEM: ECS
Chipset: P4X266-8233 //VIA LW
There's an URL, too: http://serv.ecs.com.tw/pm/bios.html, but it seems to be no longer valid.
I downloaded BIOS Agent from the link you posted, but it there's a message that the file is damaged.
OEM: ECS
When you restart your system, what do yo see?
P4VXAS Ver:1.0A 08/17/2001
or
P4VXMS Ver:1.0D 08/17/2001
or
http://www.ecs.com.tw/ECSWeb/Downloads/ ... 45&LanID=0
Please copy&paste the entire string because linking directly does not work with our forum software.
The latest one only.Salodurum wrote:There are two downloads under that link. Do I need both? There's a note saying "Please do not update the BIOS if the BIOS patch doesn't pertain to your current problem."
Which one does solve my problem?
BIOS Version: 1.2b
PCB Version: 1.X
Release Date: 2002/01/22
Flash Utility: V8.20A awd820a.exe
Release Reason:
1. Patch VT8233 Version CE auot power on issue
File Name: p4vxas12b.exe
BIOS Version: 1.2
PCB Version: 1.X
Release Date: 2001/12/31
Release Reason:
1. Patch USB function fail with VT8233
File Name: p4vxas12.exe
BIOS Version: 1.1f
PCB Version: 1.0X
Release Date: 2001/11/28
Release Reason:
File Name: p4vxas11f.exe
BIOS Version: 1.1d
PCB Version: 1.0X
Release Date: 2001/10/09
Release Reason:
1. Patch x4 dimm issue
2. Change ITEM default value
File Name: p4vxas11d.exe
BIOS Version: 1.1b
PCB Version: 1.0X
Release Date: 2001/09/07
Release Reason:
1. Patch S1 can't resume issue
2. Patch VT8233 Ver:CE
File Name: p4vxas11b.exe
