I was given a low end Desktop from a friend, and I have a problem :s
It came with Case, M/board and cpu/heatsink.
Ive old memory and other components in the cupboard , managed to get it running.
The cpu is a 2.4 Celeron and is very slooooow.
Having checked google for the board's model number, looking to see if I can upgrade the cpu. Unfortunately the company that made the board is no more but I saw that an ebay seller has it http://www.ebay.co.uk/itm/New-EPOX [...] 0898214637
This info , Processors Supported: Intel Pentium 4 up to 3.0GHz @ 533MHz FSB Intel Celeron up to 2.80GHz @ 533 FSB
prompted me to buy this cpu for a fiver http://ark.intel.com/products/2745 [...] 33-MHz-FSB
From what I can gather the P4 is right for the board but when I attached it the comp ran , fans everything, bot got no video signal to the monitor. I put the celeron back in and the comp is working again, if slooow.
I was told it coud be because of the bios and maybe I should update, but how ? As the company doesnt exist , I googles the board and found driver upgrade sites offering 1.1 versions and 1.7 , 1.8.
This is where I get stuck,Im no bios expert lol
If anyone has any info/suggestions as what I could do now I'd really appreciate it.
Many thanks
Epox is no more .... CPU Bios problem
You could give the model number or fix your ebay link as this isn't working right now. I may be able to dig up some info or a newer bios or a good reason why the new CPU isn't working in this board.
