my pc chips m810 sees my amd xp 1800+ as 1150
i have a pc chips m810lmr rev 5 motherboard and i am using a xp 1800+ cpu, the computer only sees 1150mhz. i tryed setting the bios the cpu freq is set to 133Mhz but it still cant see 1800+. cand this board see xp 1800? how do i make see 1800+?
First get new BIOS from ajzchips' page http://go.to/ajz.
286-16/NEAT Chipset/4 MB Mem/40 MB HDD/512kB Tridet/WfW
rmay635703
- Chip off the ol' block
My suggestion is return the board if you can, if not you can either
1. Run the chip stable at 1150.
2. Buy a normal Athlon T-Bird 1400Mhz
3. Although the m810lmr rev 5 isn't fully compatible with XP chips, it can run them with a 100Mhz bus. If you are fairly knowlegable you can cut and pencil in bridges on the cpu to change the multiplier, the board can run the chip at 1500Mhz 100Mhz - 15x multiplier.
Look around the internet for more info if your up to "breaking" your cpu.
Good Luck
Good Luck
