Ive got this motherboard running with intel core 2 duo e6600 just got e8500 realy cheap and now wont run im guessing its the bios because i checked the chip and it supports it but couldnt find any information from the vendor its packard bell no idea what bodel is so if anyone can help much apreaciated
https://images.esellerpro.com/2131/I/13 ... ustom).JPG
https://i.imgur.com/x7aJVoK.jpg
https://i.imgur.com/Zi7LeeA.jpg
need bios update MS CUBA MS-7301
I don't know where you found information that the E8xxx CPUs are supported. The chipset on your board does not support them:
http://www.cpu-upgrade.com/mb-VIA_(chip ... 4M890.html
That is a hardware limit that cannot be overcome with any software, BIOS or otherwise. It is not just the FSB but also the voltages that are different.
https://www.bios-mods.com/forum/Thread- ... an-MS-7301
