Hallo
I have a QDI legend 6 mobo, a slocket and a Celeron 733 Mhz (FSB 66 Mhz - Coppermine).
I successfully have modified the slocket so that it can support the Celeron.
I even updated the BIOS with the appropriate CPU Microcode and flashed it succesfully....
But ... although at power on it beeps and I see the very first line of the BIOS version, the PC freezes and stops responding.
There is no memory counting, no name of the CPU....instead of the name I have this : ''CPU &20"
Any ideas????
P.S. sorry about my english
PC freezes
It seems patching the Bios with the Microcode failed or your boars is not really capable of feeding the low voltage .
If setting the Slocket to 1.8V does not work either visit www.rom.by and try this patcher ( at your own risk)
Tried the latest Beta-Bios QDI offers ?
http://www.qdi.nl/download/LX6.htm
Well I am pretty sure that the Microcode update was successful because I checked CPUCODE.BIN with a HEX editor and it seemed all right.
I also measured the voltage and I found that it is correct.
The lastest Beta-Bios of QDI was also checked with CBROM and there
isn't any microcode for my Celeron COPPERMINE (CPUID 0686)
Since the PC boots until a point ,I believe that there might be a problem
in the BIOS 's CPU identifing routines........
If the last is true , I don't have any idea to deal with it........
I want to add something: there is also a blinking cursor, but I cant type anything......
www.rom.by
Try this patcher !!
Our mods sometimes use it to patch for bigger HDD and it usually works fine with adding CPU support
Try this patcher !!
