I bought LCD monitor 1440x900 monitor for old fujitsu-siemens PC. It is Scenic N320 with SIS 661 chipset and VBIOS 2.27.00. I can't set 1440x900 on Windows, so other resolution look very bad.
Direct link
http://support.ts.fujitsu.com/Download/ ... 0D1961-A1x
or
http://webdownload.ts.fujitsu.com/downl ... ZcWWFpTxwg
(http://ts.fujitsu.com/support/downloads.html ->SCENIC N320 (SiS661+))
motherboard D1961
BIOS 1.09
FLASH BIOS UPDATE FOR DESK FLASH (D1961-A1X)
BIOS - Change V5.00 Release R1.09.1961
Date: 11.07.2005
Currently I instaled latest driver v3.93 .?
Many thanks!
I need a BIOS patch for D1961 mobo with SIS661
misterploploop
Hello,
I have the exact same issue and hardware: unsupporter widescreen resolution.
Can you send me a patched bios for this one ?
Thanks!
Thanks!
AFAIR there's no Phoenix Bios Editor available so we can't modify this Bios by replacing the VGA Bios with a recent version.
Better get a cheap VGA card, this will improve system performance by a large margin (if OnBoard VGA disabled) as you don't need to share your memory bandwidth with the OnBoard VGA anymore.
misterploploop
Okay, thanks for the advice.
Cheeers
Cheeers
