Edwin, Can you send me BIOS version 3.14? Very much appreciated!
Again, a very thank you to you and your help and site.
Willbill
Version 3.14 for A8AE-LE
Edwin,
Could you please send the 3.14 bios when you get a chance. I was having the CPU usage issue with 3.13 (40% on a dual core 4800+) and solved it by disabling the UAA High Definition Audio. I believe this uses parts of the SB450, and think the 3.14 bios will solve the problem. I'm running a thoroughly upgraded SR1710NX with XP Pro x64. Thanks.
Dave
Dave
alporter11
Could I get a copy of Compaq BOIS 3.14 also.
I was about to scrap a year old machince because of the upgrade I performed in Decmber.
i would also like 3.14 and i dont know how to install it or what i need to do so if you could help me with that too i would really appreciate it
also i have a problem with my comp not recognizing my I/O drive that is connected to my creative XFI FATALITY sound card and the remote wont work with it
ive done everything to fix it and i cant figure it out
it gets power
its hooked up right
the in and output jacks work fine
ive moved the card to diff slots
oh and one more thing
i cant get into my bios setup ever since i swapped cases and everytime it starts up it says system fan not working but they all work
the boot menu works fine
thanks, chet
it gets power
its hooked up right
thanks, chet
5th posting in this thread has info on flashing and how to solve the fan error:
http://www.wimsbios.com/phpBB2/topic8350.html
Use F11 instead of F1 to go into the bios.iamme wrote:i installed the bios and it works great but the fan warning seems to be blocking me from getting into any kind of setup except the boot menu
i really want to turn it off but i cant
that doesnt workedwin wrote:Use F11 instead of F1 to go into the bios.iamme wrote:i installed the bios and it works great but the fan warning seems to be blocking me from getting into any kind of setup except the boot menu
ive tried many times
edonaldson
