I have two new HP Pavilion AMD dual-core laptops but i cannot use them for this purpose - the input jack is a combined mic/line input and would blow up if i connect the amplifier outputs to it (which is needed for doing measurements with the audioTester program).
So i have gotten this PIII machine i want to use for my measuring software. I'm having tons and tons of grief trying to get this thing together. It's a MSI 815EP Pro with the latest BIOS v3.3. CPU is at 733MHz, RAM 2x 64MB running at 133MHz, Riva TNT2 AGP 32MB, Seagate 20GB. I have tried four 128MB sticks that are tested good in a friend's AMD, but the board doesn't like any of them and just spits out memtest errors like crazy so i'm stuck with only 128MB. But that's the least of my issues.
I cannot get it to install Windows 2000 or XP or 2003 properly no matter what i do. It usually hangs when starting the GUI setup. I got 2003 eXPerience Edition to install a couple times, with drivers and everything (and ACPI enabled), but upon reboot Windows self-destructed. Either NTLDR is missing, or it scrolls and scrolls and scrolls the line forever, safe mode shows it hangs when loading ACPI drivers. I have tried every option possible - swapped HDD, swapped cables, swapped video card with ATi Rage PCI, replaced capacitors, swapped power supplies, disabling ACPI/PnP, UDMA, increasing voltage, lowering CPU/RAM speed, everything. It just doesn't want to work.
I haven't tried Windows 98 or ME but i have no use for those as audioTester will only run on NT and higher. I'm betting there's some silly BIOS bug that i cannot seem to find a workaround for, maybe you can help? This mobo does have some pretty nice features so i would like to get it working.
