Hello all, I have spent 2 days and am so close to being able to flash my OEM Gateway board I can taste it. I can now fool IFLASH in to loading up the bio files that I want, and get to the point at which IFLASH says "Flashing ROM". And then I get an authentication error. I have narrowed the problem down to the SIG file. Intel SIG files and 90% the same, until the very end of the file which contains a BIOS code and a small digital signature. The digital signature must match the BIOS code both in the SIG file and in the BIO files. Changing the BIOS code in all of the BIO files, for some reason, still doesn't fix the problem. My question is, is the SIG file hackable? Can it be done using Intel's Integrator Tools? I need to get myself a copy of that. Anyone have it?
Any other ideas?
One other thing: It is possible to take all of the BIO files and convert it in to a single BIN file for use with UNIFLASH?
Thanks,
Zebron
Intel SIG files: Are they hackable?
Hi Edwin, I am not quite sure whether my mobo is not working right or I am not doing something right, but I have tried the recovery method with both bootable and non-bootable diskettes with the proper .rec files for the mobo. The floppy whirls for about 3 seconds, and then nothing happens (after about 30 minutes I just shut the computer off...)
Any ideas?
Any ideas?
