I just bought a new BIOS for my HPPaviliona170.no from esupport.com.
I received a file from esupport, flashed it the computer did not boot after that.
Hotflashed my chip to the origianl BIOS in another mainboard, so now it works again.
Later on I tried to flash again with the same results and more hotflashes needed.
Now I found this forum, and I'm wondering if any of you guys here can shed some more lights to why the BIOS i received doesn't work??
The main reason for me to upgrade is that I would like to try some overclocking, besides from that the geek factor
Here is the dump i got from the program esupport wanted me to run.
Also, I've seen that if you open a BIOS BIN file in eg. winrar it will open up and show another file inside. Any specs. on this format?? SHould I decompress the BIN file and flash again with the file inside???
Regards
TommyE
BIOS Date: 09/23/03
BIOS Type: Phoenix-Award BIOS v6.00PG
BIOS ID: 09/23/2003-i845G-W627-6A69VM4WC
OEM Sign-On: Copyright 2003 by Hewlett Packard Company
Rev. 3.25 09/23/2003
Chipset: Intel 2560 rev 3
Superio: Unknown
OS: WinXP SP2
CPU: Intel Pentium 4 Processor 3066 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 512K
Memory Installed: 1024 MB
Memory Maximum: 2048 MB
Memory Slot 01: 512 MB
Memory Slot 02: 512 MB
