Hi amig@s,
I read about updating my BIOS (Award Modular BIOS v6.00PG), but I don't know why and how it is going to improve my PC. Could you please let me know the need of the update and how to update it? Is it risky? Can I crash my Pc?
Details:
BIOS Date: 06/11/03
BIOS ID: 06/11/2003-i865PE-6A79ZG00C
OEM Sign-On: Intel 865PE AGPSet BIOS for 8ISXT F2 FS
Chipset: Intel 2570 rev 2
Superio: ITE 8712F rev 5 found at port 2Eh
OS: WinXP SP2
CPU: Intel Pentium(R) 4 2800 Mhz MAX: 3600 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 512 MB
Memory Maximum: 4096 MB
Memory Slot 01: 256 MB
Memory Slot 02: 0 MB
Memory Slot 03: 256 MB
Memory Slot 04: 0 MB
Why do I need to update my BIOS (Award Modular BIOS v6.00PG)
It's always a bit risky to update your Bios and a lot more risky if you don't know what you are doing.
Don't change a running system !
You only need to update you Bios if you run into a specific problem cured with a newer Bios.
You seem to have a Gigabyte GA-8ISXT mainboard using the F2 Bios . The FS might be there because you are using a Fujitsu-Siemens computer, support has then to come from FSC.
