I have a box that used to be a satellite router, and since it hasnt been used for almost a year, I figured I'd make it into a thin client. It's a BCom WinNET VI which is Geode based.
Does anyone have either a BIOS image for this device, or a method for getting arround an M-Systems DOC TrueFFS BIOS (this boots off the DOC 2000 chip without following the BIOS boot sequence)??
Or could I just use a BIOS from some other Geode board? If so, anyone got any boards in mind?
Geode board problem (involving Disk On Chip BIOS)
If you can't mod it, it's not worth owning.
never mind... Decided to have a girl look (ie, look properly) at what's in the box... Turns out the DOC was more removable than I thought. Popped it out and now everything's cool.
