Need bios
After upgrading to 3.13 I am having the same cpu utilization problem. It even occurs in windows vista. Specifically, it is not a "windows process" that is using the cpu but hardware interrupts. This is not seen in (xp) task manager but can be seen in other process explorers. I suppose I too need to change the bios but there is now NO bios on the HP site.
thegreatfixer
hi all i have 2 of the same machines Compaq SR1710NX (from Compusa $200 AR)
1 of them was having problems so i dropped in a new bigger HD want to HP/Compaq and found the needed Modem, Audio, Video and Lan Drivers then i saw the 3.13 Mobo Bios "update" so i added that one too WHAT a mistake after putting in 3.13 i have the same problems everyone here is having CPU maxing out doing nothing i checked my other good factory machine and it has 3.14 from Compaq whats up with that so can you please add me to your long list to PM with 3.14
and may i ask for some info on how to flash the bios if its not done with windows thank you very much
thegreatfdixer
PS i am having a horrible time trying to get ALTIRIS (SVS) to work anyone else try it and get it to work my system turns off when i try to create a layer
thegreatfdixer
you both have got mail.
thegreatfixer: bflash is the one you want or maybe even uniflash from http://www.uniflash.org
about the Altiris part, what are the specs of the machine you are running this on?
thegreatfixer
here is some more info i just found on this site about the board
http://www.wimsbios.com/phpBB2/topic7855.html
here are the Vital stats that come up in Balarc Advisor hope this helps
thank you thegreatfixer
Operating System
Windows XP Home Edition Service Pack 2 (build 2600)
System Model
Compaq Presario 061 EL426AA-ABA SR1710NX NA610 0n41411RE101AMBEM00
System Serial Number: ----------
Enclosure Type: Desktop
Processor
2.00 gigahertz AMD Sempron
128 kilobyte primary memory cache
128 kilobyte secondary memory cache
Main Circuit Board
Board: ASUSTek Computer INC. Amberine M 1.03
Bus Clock: 200 megahertz
BIOS: Phoenix Technologies, LTD 3.14 01/17/2006
Controllers
Primary IDE Channel [Controller] (2x)
Secondary IDE Channel [Controller] (2x)
Standard Dual Channel PCI IDE Controller (2x)
Display
ATI RADEON XPRESS 200 Series [Display adapter]
ViewSonic 75 [Monitor] (15.7"vis, s/n DD84912781, December 1998)
Bus Adapters
Standard Enhanced PCI to USB Host Controller
Standard OpenHCD USB Host Controller (2x)
Multimedia
Realtek AC'97 Audio
Communications
PCI Data Fax SoftModem with SmartCP
1394 Net Adapter
Realtek RTL8139/810x Family Fast Ethernet NIC
Other Devices
VIA OHCI Compliant IEEE 1394 Host Controller
HID-compliant consumer control device (3x)
HID-compliant device (6x)
USB Human Interface Device (4x)
HID Keyboard Device
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
HID-compliant mouse (2x)
USB Composite Device
USB Mass Storage Device (2x)
USB Root Hub (3x)
Operating System
System Model
Processor
Main Circuit Board
Controllers
Display
Bus Adapters
Multimedia
Realtek AC'97 Audio
Communications
1394 Net Adapter
Other Devices
HID Keyboard Device
USB Root Hub (3x)
kingandson
me
I need 3.14 bios too
cpu high work, because 3.14 support sb450 , dont support sb400
kingandson
I use 3.13. -> High Cpu Utilization
I debug bios . 3.13 is for southbridge sb400. You can get information when boot.
but my southbridge is ati sb450. and bios flash is 3.14 ( clear letter on bios flash ). and ati sb450 ( clear letter on motherboard )
High Cpu Utilization because IDE control and MS UAA Driver use same ( bus & pci & F )
You trun off MS UAA , Cpu Utilization get low.
Updata bios . first get backup, no backup no updata. ( Dvd rw is total loss for I debug. )
kingandson
you check motherboard.
sb450 use 3.13 , install MS UAA Driver 100% get High Cpu Utilization,
sb400 use 3.14 , information unknow. I dont have the motherboard.
okay... They shipped boards with new hardware but with the old bios. Not very clever. I begin to see a pattern here...
Here's the main thread on this board BTW:
http://www.wimsbios.com/phpBB2/topic8350.html
