Problem with A8AE-LE bios upgrade
I have one report of a failed flash with the 314.bin given to me. Beware. Make sure you use a NEW floppy to avoid errors as much as possible.
If it's a relatively new harddisk, yes. But I have seen too many reports of failed flashes from a harddisk to not 100% believe this is the best method. Whatever the medium you choose, make sure it's not too old and abused...70mustang wrote:The D: drive (restoration partion) on my pc is FAT32 so it can be accessed from the DOS promp. I recommend using the HD as it is much more reliable than storing the files on a floppy.
Perry
Yes, either that or bad cabling. In one case a virus.
I have a guaranteed working bios file now:
http://www.wimsbios.com/phpBB2/topic8350.html
