i just ordered a brand new computer i got the
antec 900
MSI970-G65
AMD Phenom II 955
Sappire 4890
Muskin RAM 2GBx2GB
WD 640 GB Harddrive
HP DVD burner
Corshair 850 watt PSU
i put this all together and booted up everything seemed fine....
but when i try and install windows it freezes up at random spots
i also tryed a vista disk and it also will randomly freeze up.
i tried a different hard drive and DVD drive will no success
i tried taking one stick of ram out and leaving the other stick in
and vise versa. but nothing im doing this project for my senior project and this would be really great if i could get some help on this problem
THANKS!
i have also flashed my bios to v1.3 this has done nothing so far. still the same problem
my friend thinks this may be a motherboard issue please help me
Help! Freezing on installation
One comment:
PSU is way overpowered - a quality 500W PSU is more than enough.
Tips:
Make sure the system is properly cooled, especially CPU and VGA need to have proper airflow. Verify your memory runs with the voltage specified by the memory manufacturer - if it's one of those OC RAM then they may need a lot more juice to acheive their rated speed and timings.
Tips:
