Hello. I have a Jetway JNF91-600-LF integrated motherboard and the ADPCM2 daughter board which adds a PCMCIA slot and Compact Flash slot. I would like to boot this computer from the CF slot, however there is no option in the BIOS.
I have contacted Jetway Computer Tech support and they have told me that it "is possible", but the Award BIOS would need to be modified, and they are unwilling to do it since they would need to purchase a license from Award to modify it as the manufacturer, and it is not cost effective since the board is discontinued. I was hoping perhaps one of the gurus here could take a look at the BIOS code and see if it is possible.
A link to the motherboard on the Jetway site is here: http://jetwaycomputer.com/NF91.html
A link to the latest BIOS is here: http://www.jetwaytw.com/bios/NF9XA01.zip
Although there is no link on their site to the ADPCM2 daughter board, it connects to the 120-pin connector on the motherboard, which I have been told by Jetway is basically a PCI interface.
Any help is appreciated.
Jetway JNF91-600-LF with Award BIOS need modification
If that daughter card is bootable in the first place (somehow i think it is not), you should be able to set the mainboard bios boot priority to "Bootable add-in card" first. That should work. Just as any SCSI or SATA or IDE add-in card on the PCI-bus.
