I have motherboard Foxconn 915M07C-G-6LS. I cannot find a new BIOS for this. Motherboard often stops. Nothing responds. It looks like a BIOS damage.
I cannot find a BIOS update. There is nothing on the Foxconn's site. It looks like this model isn't exist !
Could you help me ? Or tell me how this motherboard should name ? On the Foxconn's site every motherboard isn't match.
Foxconn 915M07C-G-6LS BIOS
http://www.foxconnchannel.com/EN-US/Upl ... %20CPU.htm
Most likely it is this one then:
http://www.foxconnchannel.com/product/M ... -us0000104
There is one other possible problem for your board that can cause stopping: bad capacitors, check your motherboard and power supply for this:
http://www.badcaps.net
Thanks, for find the BIOS.
Capacitors looks good. I bought this mo-bo with celeron via allegro (sth like polish ebay). The seller told me, that he used this and hadn't any problems before.
I have one question. Could this motherboard stop while the BIOS will be updating ?
yes. you really need to find the source of the problem. the BIOS is very likely not the source. you should run the board with something like memtest86, mersienne prime and some linux live-cd to find out if it's hardware or software related.I have one question. Could this motherboard stop while the BIOS will be updating ?
what kind of RAM and power supply are you using?
RAM is good, because on other computers is working.
The power supply was working good on oher configuration, even on the "strongest" configuration.
The battery has 3V - good,
resetting CMOS - motherboard still stop
RAM can be good but not be compatible with this board, not really matching, that sometimes happens.
You still need to give the make and model so we can check if it is fitting this board.
Not listed. Below is what Kingston memory is known compatible with this board. Got any other stick you can try?
KVR333X64C25/512 512MB 333MHz DDR Non-ECC CL2.5 DIMM
KVR400X64C3A/512 512MB 400MHz DDR Non-ECC CL3 (3-3-3) DIMM
KVR533D2N4/1G 1GB 533MHz DDR2 Non-ECC CL4 DIMM
KVR400D2N3/1G 1GB 400MHz DDR2 Non-ECC CL3 DIMM
KVR333X64C25/1G 1GB 333MHz DDR Non-ECC CL2.5 DIMM
KVR400X64C3A/1G 1GB 400MHz DDR Non-ECC CL3 (3-3-3) DIMM
